8 minutes ago, SbTVF said:
Uniforest Titan 40/20 is probably your best/only option if you want a tow behind. Never seen the other makes with an axle on.
And looking at it they are tractor tow only. I have never seen a regular tow processor with circular saw.
Why the need for circular saw?
2 hours ago, SbTVF said:
That, I hadn’t noticed!
Chainsaw options are regon or wp36 off the top of my head then.
Only one I could add to that is the Trakmet but looked like it was poorly adapted for road tow with the chip being fired out straight into the wheel. Dont think there is anything to touch the Farmi in the road tow sector.
thanks  for  replies   got   a  posch  350  done  500  tons    blade   still  good   if  it  was   a   chainsaw    be  forever   sharpening   and  got  lads    working  it   must   be   a  circular    saw    been  told   palax   do   one   waiting   for   a   brochure   to  come  thanks   anyway   philip
Details of the Palax road towable.   Looks to be good for small stuff <10".
NEW Palax D270 Active
This newly redesigned model based on the old Palax Ks Active
This machine can cut, split and stock pile logs up to 270mm in diameter
• Very Safe – Rams stops when guards are open
• Very fast – Quick circular saw cross cut operation
• Very Low Maintenance – No V – belts
• Very Easy to Use – Simple operation
• Very Low Power Required – gx390 Honda industrial petrol engine
This machine has been in production for many years and has been very well developed over that time to give you a machine that just keeps delivering firewood off the end of the conveyor without down time.
Excellent portable machine for tree surgeons.
• 13&quot; Hydraulic chainsaw.
• 2way - 4way Splitting Axe
• High Speed Valve - Automatic Variable Speed Splitting
• 2.7m Discharge Conveyor.
thanks  for  your   help  palax   I  think   its  going to   be      philip
