Won’t cut straight- new bar and chain??
SbTVF
Both bar and chain are brand new and made half a dozen cuts so not my sharpening at fault. The cutters all look even to me too.
The chain matches the bar as it’s 95TXL in 0.050.
Ill re-tension and try again tomorrow, ran out of daylight to try today.
Thanks for the help so far!
If there " damage " to the bar is not evident  yet ( un even bar rails caused by chain  pulling to one side ) remove the Husqvarna made original powermate and replace it with an Oregon one . Another quick check wou;d be to turn the original owermate round on the spline and see if it "bananas " the other way . I think there may be a problem with the OEM  rim .
Edited by Stubby
Ok thanks I’ll turn the powermate round first. Turning the bar over didn’t change the direction of banana I don’t think.
It’s not done a great amount of work to be honest so I’d be surprised but I’ll get all those checked out.
Oregon are happy to take the bar and chain back fir testing and replace under warranty but I’d best make sure it’s not my saw before I waste the postage!
Would a 18” bar show sprocket or needle bearing issues more than a 15” bar?
So I just went to take the spark plug out so I can stop the piston coming up to take the clutch off and the spark plug was loose as buggery. Took a good 3 or 4 full turns to put it back in. Then when to wind it out and it went really stiff as though it had cross threaded. On closer inspection the final thread is damaged slightly. Weird!
I've never touched it from new so god know whats happening there! Still not managed to turn the power mate over. Will have another go tomorrow when i've got a new spark plug!
