These saws do give trouble some times,but they can be sorted,and when they run right theres nothing to touch them.
I've been using 020ts or 200ts for 14 years and only had bother with the last 3,which were all sorted same day under warrenty.
I had the same with mine took it in to uncle Dicks and it came out with new carb.It worked out under a ton and a lot cheeper than replacing it.
Aparently i was told there was a bad batch of carbs on the 200s but i love the saw.
