So my 365 spark plug has threaded in the cyclinder, got it sent off to be heli-coiled, but the blokes done a poor job and it's came straight back out. So I fancy myself having a crack but I'm unsure on what's best to a rethread kit or heli-coil ??
Also wondering what size I would be after.
cheers chaps
I would suggest that getting some cheap kit off ebay is a short cut to trashing the cylinder! I invested in the correct kit some time ago and includes various taps, reamers and wrenches. I use a mix of helicoils, stainless or carbon steel inserts depending on hole size and damage.
The issue here is that the original repair has failed, this is probably due to the receiving thread being poorly formed by a cheap tap or the repair been poorly carried out. If a new insert is a loose fit when this thread has been chased out, you will be forced to go to the next size up of insert. This will depend on the land around the hole, your insert and tap system......welcome to my land! The benefit of solid inserts is that you can use thread-lock on them.
Just now, htb said:
Thought you would be along soon
Well....had to be didn't I....I actually tried one of those £10 ones off ebay in the early days.....totally shyte and fortunately it was on a shot cylinder!
Ah I'm glad I posted this because the place I was heading was eBay. As the cyclinder is in good condition I think I'll just take it into someone else with the proper kit and know how. Thanks a lot!
I tried to buy a good quality set, only to find it was a Neilson (?) when it arrived. The drill bit was so bent and out of true it wouldn't roll on a flat surface!
Engineering works next door drilled and retapped it for a tenner.
