Woodworm
billpierce
Hi, having re-investigated the uses of borax powder solution since reading the info provided earlier in this thread, and just to satisfy myself that I'm not being exposed to unnecessarily to any danger, I've not come up with any reason to stop using it.
It would seem that the borax method of treating timber is considered to be the natural way as opposed to many of the brand name products in which the active ingredient is permethrin.
Obviously you ultimately have to make up your own mind when deciding how to treat your woodworm problem.
I've no scientific training so I'll correct myself in that the solution I use is 10 per cent not saturated, also it's borax crystal powder solution not boric acid {if that makes a difference}. I'm sure there are folk on here who have more experience of using this stuff than myself.
https://www.greenshop.co.uk/documents/borax_timber.pdf
There's a lot of reading out there on this subject, much of it tangled in controversy, but if it was me I'd inject it down the holes to get the woodworm, once successfully treated fill the holes with epoxy, re-sand and re-oil and I doubt if there would be any residual danger, good luck.... whatever you decide to do.
