550xp chain brake
edam321
Bit late on the reply I know. I use a similar technique but instead of a screwdriver, I use one jaw of a crocodile pliers. That way there's no worry about slipping and you can ensure the spring doesn't buckle or pop back out. After fitting the cover plate, I then reset the brake by gripping one of the arms with a normal pliers and a quick twist resets the brake to off.
Edited by TGB
