Old red briggs 3 hp vertical with metal carb and autochoke diaphragm is running erratically. Is this carb missing a spring and cap to fit in that hole? Are they 692206 & 690766?
[ATTACH]220974[/ATTACH]
Yes Mike, there should be a spring and cap in the recess, with the cap resting on the diaphragm. Without these the fuel pump will not operate.
And you are spot on with your part numbers!
I would not bother with that carb though. Get a modern Pulsa Jet carb and tank from a Sprint engine off a rusted out mower. Much easier to start.
Edited by GardenKit
Thanks very much Barrie - & thanks for confirmation re: part numbers - great vid too - cheers all - much appreciated. Tried a more modern carb but aluminium breather tube was too long- reluctant to take a hacksaw to the old girl :)
