I do a lot of hedgecutting and have been chewing over the idea of getting a battery powered long reach hedgecutter.
The one i was thinking of is a stihl HLA85 with the AL500 AND AP300 battery.
Now all in the cost is close to Β£600, so thats a lot of money!
I just wanted to know if anyone has got any experience of using these and what sort of size growth they could handle? Like would they be ok on a years growth on a hawthorn hedge or is that asking to much of it?
Β
Cheers, James.
Have more experience with the long reach hedgecutter than the handheld so can't really comment. What I would say regarding the cost though is that those same batteries will go in any of the other units, which are reasonably priced individually.
Β
Β
Β
Β
Β
It's the long reach I'm interested in :biggrin:
A friend of mine used to have one, and from what I heard the batterys die of pretty quick.
Β
Do you know which batteries he was using? There are a few different ones the more you pay the longer they are suppose to last...
Had the Hla 85 for over 2 year's now and fairly impressed but for a years growth on Hawthorn has a one off yes , the blades are the same has the top of the range handheld cutters (double sided) Privet hedges and Conifers it loves .
I have had a warranty issue over the clamp on the telescopic bit which to be fair is utterly crap .
The motor is located at the end so it's a direct drive for those that are not mechanical minded.
Β
Β
Ste
Edited by IVECOKID
Β
Β
Ste
Β
Cheers for the input, how do you find battery life?
Β
I use the older 115ap and 180ap , the 115 is fine for the Top handle saw to keep it like a feather but otherwise crap for hedge-cutters.
The 180/200 does me proud but I believe the new 300 is the one .
I have the strimmer,long and normal hedge-cutters plus the top handle saw and they have made my life on the Garden maintenance and lot easier on the repetitive starting etc .
Ste
Edited by IVECOKID
Β
I am afraid not, I only know he had to replace the battery after about 4 months
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
