Alaskan saw mills
Chris Harris
I've not long bought an Alaskan saw mill & i'm really enjoying playing around turning some of my pile of timber into fence rails & posts etc. (i'm easily pleased!). Today i milled a 8x8" by 6ft oak post to replace a broken gate post at the yard, again i was pleased with the result but i could'nt quite get it square. I was wondering how you other millers manage to get square cuts & also if theres any other good tips for getting good cuts. At the mo i just cut of any bits that are sticking out then place a ladder section on top to make my first cut. Does anyone else use this or are there any better methods, cheers Chris
  • Replies 20
  • 1 month later...
No matty, I dont have a ripping chain, yet, and tbh I dont think I'll bother. I was using a chain on its last legs for that slab, and it cut well. Some recommend filing the chain to about 10deg angle, but i havent tried that yet. Yes its easy to set up and use, the oiler I'm making up is for when I use the 090 (manual oiler) and button for that is going to be awkward to depress when the saw is set up to mill.
so is the o90 manual oiling or do you need the exta oil when milling... i ripped some planks of yew the other day with the 395 with out the mill(seem a waste as the customers firewood)...came out very rough and a bit dodge dont think the chain was oiling to well... dont think the victorian garden hoe i found in the middle helped to much either! but i was pleased with the rough result. i imagine the mill by yours pics would of done a much better job
It's good to see that you're getting good results on the dougie with standard chain. I've just got a ripping chain for my mill and the difference it makes is noticeable, both in finish and speed of cut. I would recommend getting some if you're going to cut Oak and the like, or bigger widths. What's the dougie going to end up as?
:wave:
