I have just had to fit four new springs to my IW LM146 trailer, it's the kind with 2-leaf parabolic springs. Does anyone know the recommended torque for the four nuts on the two U bolts on each spring?
If no-one knows I'll ask IW in the morning, but it would be nice to get it all finished tonight!
Many thanks.
IW has given me the following information which I will post here just in case anyone else needs it in the future.
The U bolt nut should be tightened to 140 Nm (103 lb ft). Note, it is essential that the correct flanged Nyloc nut is used rather than a standard Nyloc, since the latter, when torqued to 140 Nm, can cause the U bolts to shear.
The spring eye bolt nut should be tightened to 80 Nm (60 lb ft).
Note that IW also recommends that the U bolt nuts are checked and tightened every 1000 miles or 2 months.
Very helpful people at IW. :thumbup1:
Edited by Treewolf
Yes, the two nearside springs had both broken, cracked through the eye. I could have replaced two putting new springs on one axle and both old on the other, but they're not too expensive so I figured four new was the best bet.
140Nm is terrifyingly tight for an M12 thread though! I was sure the U bolt was going to fail.
