Hi all, long time lurker here. i know this has been discussed in the past, i just can't find the post. anyway the question is how much does a 1m3 vented bag weigh before drying and after. 185Kg springs to mind for dry, but i also need to know fresh cut as i need to buy a tractor ... on a tight budget
Ah this can of worms :laugh1:
I work on 1m3 of wet hardwood logs being 500kg and dry to around 350kg. Beware that a lot of 1m3 bags hold more than spec even when new and get bigger through use.
About 300-350 when below 20% moisture. Comfortably 500kg wet. Hardwood that is.
Softwood will be 250kg dry tops.
Sent from my iPhone using Tapatalk
