YANMAR V1050 DIGGER | RJ and KD McLean Ltd – Tractors and Plant
Eddie
Would this machine be able to run a shear with a rotate function as well?
If you can tell from a quick glance at a picture....
Yes the Yanmar in the image certainly appears to have the necessary twin auxiliary circuits required for not only a shear with rotate function, but a Timber or Selector grab with rotate too if required.
As for Shear, if it's cut and drop you want then nothing to match an Exac-one cutting head. Cut and hold with a percentage chance of dropping material then an Intermercato Tiger Cut 200 can take any abuse you can throw at it! However the TMK simply can't be ignored? Incredible cut capacity and I'll tell you the trick to cutting half as much again as it's rating after this test one has gone back!!:biggrin:
TMK will also do a lightened version in thinner plate if weight is an issue.
Eddie.
  • Replies 42
Eddie.
Thanks Eddie, I know the tiger cut version has the option for a rotator as well where as I'm not sure if tmk offer a rotator version? Other wise you'd be going down the rototilt option as well?
One tip with the tiger cut, make certain the blade bolts are tight, and I mean tight, slightest play in them and my 8 tonner would fetch the whole set off in one go. Not the Shear's fault, I used it brutally under the Engcon on the 8 tonner, as the Engcon lets you pull at all sorts of odd angles.
Anyone purchasing for a 5 tonner can be confident you'll never hurt it!:thumbup1:
Eddie.
You will surprise yourself what you will achieve with a TMK and no rotate. They have a demo day in a week or so somewhere?
You have to remember that the steeper the angle from vertical the more chance it will get away from you with either the Tiger or the TMK.
Eddie.
Eddie.
To be honest I hadn't thought about that, it would need to grab and then cut to work well in that function I guess
Would you say a 5 tonnes is to small a machine?
No I certainly wouldn't, a lot handier to transport and pack a lot more punch than many would give them credit for.
It will do some serious work in a shift.
Eddie.
Yes that's why I ended up building my own. I used the Tiger cut minus the blade as the ultimate bombproof gripper unit and added the unrivalled Exac-One cutter underneath. Best off all worlds with the bonus of fully independent control of either grip or cutter unit.
You should see that go under the Engcon on my 8 tonner. You'd pay £22k to match it with a Westtech!
Eddie
