Husqvarna used these sealed bearings on a number of machines, not the greatest of ideas as it gets expensive if a seal fails. The oil pump was a strange device and prone to get bent if adjusted badly.
Not a great saw but you can get them going OK if careful.
The coil was a bit weird to, two contacts with a close tolerance to the flywheel and another with a massive gap. Get it wrong and the thing sounded like a sack of.......:thumbdown:
Ba humbug to all of you i thought the 335 and later 338 were great saws way ahead of its time, the bearigs were sealed with the seal inboard so no crap in the bearings, the balance was correct just the oposite of the Stihl, the later cylinder can be fitted to the early 335/339 you just need to fit the later inlet tube and clamp, simple saw to work on, only pump issues were idiots taking the adjuster screw out and refitting without pushing the pump shaft back. know the saw inside out and love them.
:biggrin:
