Does anyone else who owns one of these find that the chain doesn't oil that well - the adjustable screw is turned, so it should be oiling the most.
Thanks in advance
Yup, most likely a plugged oil pump - just remove it and make sure the inlet and outlet union are both clear. It is unlikely to be the worm drive, only ever changed one on MS200/201s and that one was fried due to woodchip and bio oil contamination!
I bunged the whole lot up Steve!
Cutting filth for days with no may-tay-nance downtime.
To be fair, the worm drive was very worn, old 200.
I will let you off, three Hail Marys and you will have absolution:thumbup:
thought the same myself, guess this means it only oils when it needs to lol
Ematic chain lubrication system
The Ematic chain lubrication system ensures pinpoint lubrication of the saw chain links and guide bar rails. When used with STIHL OILOMATIC saw chain, it will provide maximum lubrication, longer wear and less oil consumption than conventional methods of chain lubrication. The Ematic system can reduce bar oil consumption by up to 50%.
