I am going to fabricate a tilting table for my band mill but I can't decide which way to orientate the cants.
I could have a single table that rocks from side to side and position the cants so that the end grain faces the side rails or...
I could have individual tables that rock in line with the bed so that the end grain on the cants face the ends of the side rails.
Hope that makes sense!
Cheers for that, that's an example of the 2nd method of the 2 I was contemplating.
If I had the cants sideways on to the blade on a single table I would get more on but clamping the cants would need more thinking.
Edited by Wendelspanswick
It's easier to mill the timber in method 2, as in the pictures above, and will give a better surface finish.
I have built a shingle jig myself and am now finishing off a modified version, actually very similar to the one pictured above. The cants are clamped onto a frame that lifts with cams to give the angled cut. Well worth the effort of building a decent one.
the second method is the prefered way for shingles, up down alternatefor a pair, your first way, lifting the edge parrallel to the rail will give you taper edge boards for clading, or fences
