Just read this , did you manage to get it sorted,...?
If 'lid' comes up on the display on a Quad then it's most likely the 'link' wire in the harness behind the battery by the fuses.
It's a simple loop of wire on a small plug that simply makes a circuit as this feature isn't required for a switch on the Quad.
If you can find the 'link' then just unplug it and make sure the contacts look good and clean, refit it and test to see if it's cured the fault.
If not, give us a ring at Greenmech and we can talk you through re programming the computer software..
:001_smile:
