Electric splitter
Mull
It gives the motor it's direction by changing the timing of the voltage in the start winding relative to the run winding. No start circuit and it's 50/50 which direction the motor runs.
ok, it's something I've never seen mind, (I'm no electrician).
Assuming that the new Cap that Mull fitted is good why would the motor still run backwards?
He checked the windings with his meter.
  • Replies 40
Does the cancelling out of the start circuit change the polarity?
I feel I'm digging myself a deep hole here. :biggrin:
No. Think of two separate windings each supplied by the sinsudoidal mains voltage. The capacitor changes the timing between these two waves and this affects the magnetic field which drives the rotor in one direction or the other.
If you change the polarity of either start or field winding then a serviceable motor will run in the opposite direction. Change both it will stay running in the same direction.
Was this a test? If it was I did the same one about 45 years ago.
I suspect I can guess your capacitor test method and it always seems impressive.
I'm sure you're right not to put that on a public forum though.
