Kubuta v2203 bleeding
mark hooper
which valve are you meaning can you take a picture of it
If its the same as my mini digger, its a thumb screw on the side of the injector pump. You unscrew it to bleed the system, once its running you screw it in and it should be sorted.
I was wondering that I thought most were using the 10mm screw to bleed it
