  • Replies 52
  AllyH said:
Does anyone know if aspen 50:1 mix contains ethanol? And will it be ok for the 550xp?
It contains NO ethanol and it is the fuel that Husqvarna test all thier saws with at the factory . They also recommend it strangely enough . I know it should not matter but any warranty issues can not be blamed on " bad mix " if you use Aspen .
  AllyH said:
Brilliant. I will try some of this. Hard to find in Dumfries though!!
Maybe the dealer you work for would consider stocking it ?
I absolutely love the saw. Anything to make it better id be a happy chappy. Spoke to husky tech today and the recommend using super unleaded. What do you use Gary?
Read more
