Hi all !
Has anyone bought crates of kiln dry in and if so what volume loose did you get ?
I bought a few in last season and a 2 cubic meter crate didn't give much more because the logs were small.
If you work the other way, a cubic metre of loose logs tends to work out at 0.65 to 0.7 m3 when stacked. So find the internal volume of the crates you are buying and that should be a good guide. Crates I've had in the past have broken down to about 2 3/4 metres but again it depends on your crate size as they aren't all euro pallets.
  • 3 weeks later...
