I'm using filtered used ATF in my Titan & it seems to oil really well. ATF is a lot less viscous than normal bar oil, so that may be why? My bar is fine & second chain is on its fourth sharpening. I cut mostly hedgelaying waste 2-6" dia on a bulk saw horse which holds a bundle about 18" or so in diameter, but no bar/oiling troubles at all.
  • Replies 32
The vibes on electric saws are dreadful.
This can be true just as Steve says, but not all electrics are bad.
For instance the new Stiga SC80 AE 80Volt rechargeable saw with a 16" bar has levels of 4.18 front and 3.47 rear.
This is comparable with say, an Ms231 which has 3.9 front and rear.
