Green Mech Eco Arborist engine WANTED
Tikka
The crank shaft has snaped on our Greenmech EcoArborist so Im after a replacement engine, has anyone got one for sale or another knackered ecoarborist so I can use the engine?
Engine details are- Isuzu 3LB1.
Family # is 3LB1NAB.
Type # is 3LB1NABDA.
Id # is 3LB1 435295.
Thanks in advance. John
John are you sure it's the 'crankshaft' as I've never heard of this before on the 3LB1, have you checked that it's not the 'flexi plates' on the engine drive shaft that have given up.....?
Jase..
Edited by Jase hutch
Missed out a word...
Apparently the engine is now obsolete....... I have sourced a new crank shaft £2600+vat, I will also need a gasket kit, bearings and shells. Ive been told some water pumps used the same engine too, so going to wait and see what turns up. Cheers
