Hello,
Thinking about building a kiln can weld fabricate do most things wanting to use either insulated containers, old fridge backs off lorries question is how to heat them without it costing a fortune for setup thought about waste oil heater any other suggestions?
Also do you split the logs then kiln or ring kiln then split? and how do you store them after?
