Problem with my 150, when I'm chipping larger material and the stress kicks in, the rollers stop as they should, but then won't start going again, I have to reverse the rollers and keep pressing the green forward button and will eventually kick in and and start again!
Suggestions
Have you tried changing the latch relay beside the stress control box, its a normal relay available from car shops
Not sure! I'm no good with stuff like that lol
Thats the one, partially covered by the white mounting pin in the bottom right of the pic.
there only a couple of quid, just pull it out of the connecter and replace, worth carrying a couple
Cheers I'll try it 👍🏻
Start with taking the relay out and giving the pins and maybe the terminals a clean, still no joy then try a new one
Cheers! I'll try it tomorrow see if any luck 👍🏻
Make sure the throttle isn't vibrating back a little bit, it happened on mine with the same sort of symptoms.
