Seen a few people on here mention about removing the spark arrestor from their saws to give it a little more power, just wondering how much difference it actually makes, what problems it could cause, and whether to put the screw back in when you take the screen off?
J
J
Take it out , put the screen and the screw in a bag just in case you work on a sight that requires it . On its own wont make a huge difference but it mill make some . Will run very slightly cooler .
Cheers [emoji2]
The screen blocks about 20% of the exhaust outlet, and that's when it is clean.
The only disadvantage I can see with removing it is that foreign objects, insects etc may get into the muffler - but it hasn't happened yet to any of my saws, despite I always remove those screens.
A slight adjustment to the carb may be needed.
  • 3 weeks later...
Depends on where you cut. In France if it's a state owned site it has to remain in place. the reason stated to stop sparks coursing fires
He's in Wales, more chance of causing a flood there I think :thumbup:
