Hi all,
Just wandering if there may be an obvious solution.
I have a ford transit 10 plate. The turbo seems to be non existent in the lower gears mainly 1st when pulling away. It does sometime run normally through all the gears but, when it does go, you pretty much loose all the pulling power.
My question is, should I be looking for anything obvious that may have come loose or is it likely to be a bigger problem?
Thanks
air hose or egr valve suted up wit carbon up but will ask my mate he has been a ford transit technician for the last 9 years turbo pipes get someone in it rev it while your under the bonnet and try to squeeze the pipe shut when revved up also tell the person to then turn of the engine while your under the bonnet if you here a odd noise a second or two after engines off egr
