No, if you have two the right lengths they sit pretty close to each other so you can just tend one into the other.. if you're only doing light bits its probably not worth it.
We use 10mm ocean polyester home made slings (double fishermans) with DMM revolvers for ziplines. They can also be used to set up mechanical advantage set ups. They work best with 13mm host rope as the revolver gates don't open very wide.
