barton77, have a good search on you tube, I ended up making my own setting tool, do my own now with no problems, a couple of push clamps, 2 dial gauges, some angle iron, flat plate, and a welder
Are you doing a left and a right tooth every time you move the blade (2 dial gauges) or do you have to turn the blade inside out to set the second side?
aye, left set, neutral, no set, right set, found this works best for me, nice clean cut, and once you get into the way of it, quick to do a band
