Noticed my zigzag had cracked today, this will be the 3rd one and I'm sure my last replacement was meant to be the mk3, is there an easy way to tell? Cheers
Sent from my SM-G935F using Tapatalk
The top links on the Mk 3 are beefier.
If you search this forum for "oh no not another zigzag" you should be able to compare the Mk 2 to yours.
If it is a mk3 then it is the first one to crack that I have heard of. It sounds like you've ended up with a Mk2 somehow.
