Saw replacements
huskykev
I use it as a firewood saw. Seems good so far, it's very light to use. Proper ally split crank cases and two rings on the piston. Seems very well built for a 'cheaper saw'. The decomp is useful and it starts well. Typical Japanese quality:001_smile:
It would be the go-to saw for me in the jeep 24/7 just in case, 550xp is too expensive and i dont like electronics either. What bar and chain have you on yours?
i'm also primarily a landscaper who does tree work now and again, and most of that is conifer topping. I had a little stihl 017, great little saw for small work, currently have a few old husky 36's, cheap as chips and go for ever, but if I do decide to upgrade then i'll be going for an echo cs3900, problem with modern saws is they don't like sitting on the shelf too long, I have a husky 560xp, great saw for bigger work but that can be quite some time between jobs so I have to fire it up every week even when i'm not using it, In general I think echo would be more suitable, less powerful, slightly heavier, but handles prolonged storage much better.
I have it running on the18" bar it came with. Seems to pull it ok. But like I said I'm only using it for firewood. :thumbup1:
