Portawraps
Vertical Lmit
be aware on these things!
the paint can reach a high melt point along with a lowering line & cause a fusion of rope to bollard 'even' under a heavy load! it just comes to a stop mid line! i had read about it but not thought possable till i tryed to make it '& did' happen.
not had a prob with the porta wrap system with regards of line jump if tention is aplyed to the line befor a load is applied.
i have had an outer sheath of an 16mm lower line stripped on a new porta wrap prob due to weald splater & the fine gap in the part welded onto short end of wrap catching the line under load. make sure all gaps are filled & areas are smooth, ropes under load will pick up on any diffect! cycles to falure & all that jazz..
  • Replies 60
