MEWP vs. telehandler + basket
LynBugLover
Hi. Sorry if this is a bit of a daft question. When it comes to HSE regs, training etc., is there a difference between a dedicated mewp and a telehandler with a mancage attachment? We have both at the place I work, and currently the telehandler is used in preference to the Niftylift because it is perceived not to require the same level of servicing, operator training etc. I can't see the difference, to be honest. Surely a mewp is a mewp, whether it's a dedicated piece of kit, or an attachment.
Does anyone know the answer, or where I would find out?
Thanks very much
Lynette
I have used a Telehandler and man cage. When using a man cage you can only operate the boom and must keep the Telehandler stationary when there is someone in the cage. This makes getting to multiple locations on a tree tricky and slow. Telehandlers generally make quite a bit of mess on wet ground especially if you have an uncarefull operator.
The telehandler must have a loler inspection every 6 months if it is to be used to lift people.
I thought that when someone was in the basket only they could control the handler, and that for a baskt to meet regs it must have controls? I remember a lock out in the cab of some sort- maybe the steering, but may have been the joystick- in a 9m merlo where i used to work, which i think was to do with a basket.
Coincidentaly, i was held up today by a gang on roadside tre work using a handler with a basket- i never looked in the cab...
Thanks everyone that's answered. I've had a good look through LOLER and it could certainly be clearer (but then I guess that would make it all too simple, wouldn't it?). There's no question in my mind, but I can see how someone wishing to avoid the cost of 6-monthly inspections could argue that a forklift is not 'equipment for lifting persons'. I can feel a frank exchange of views coming on. Ho hum.
