Chipper playing up
swinny
sometimes theres a filter in the top of the lift pump try that
Its fuel back draining to the tank when not in use, that's why it happens shortly after the first run, its caused by air in the system that purges after a short time.
If it were a filter issue the symptom would persist, as it is the engine starts on what it has in the system between the lift pump and the injectors then sorts itself out as the air purges out via the injectors.
