  • Replies 33
just read this and from the beginning of the thread i was in agreement with Chris and the 2 GRCS's. I love stuff like this as it can be so calculated but so sketchy at the same time. Excellent work Chris. I hope 'you charged accordingly'! I need to save up and buy a GRCS.
There was a hell of a lot of weight which was why I was nervous but both pines had 2x 18mm lowering ropes,
total 4 18mm ropes on it, should be good to hold 20 ton or so if the anchors are, sounds like you incorporated a good margin of safety
I got a bit confused here - sounds more like it was 2 lines holding it up and another 2 to lower the cut sections
