Currently using a gd85 ifor. Which is good for size but now needs a new floor and a rewire and is a good few years old.
I've noticed one of the bearers is starting to bend. Not sure wether to spend a bit on it and maybe weld in some more bearers or just trade it in for new.
Β
Not sure wether to get something stronger. Probably still an ifor as the dealers just down the road... but what are the options. What are you guys using?
Β
Thanks. Dean
  • Replies 27
It depends on what else you use the trailer for? If it is just for towing a chipper about then I would look in to a Brian James tilt bed trailer, I can't remember what the model is now with out having a look
thanks guys
Β
I'm at home now, couldn't use the search function on my phone earlier for some reason.
Β
they do look good, but I may need it to be able to carry out other duties too. carrying the odd log, stump grinder.
Β
also looking at the possibility of having to carry a small 1.5 t digger.
Β
can I fit one on a gd model due to having to accommodate the arm vs draw bar length?
am I asking it to do something it just cant do?
Β
thinking at the mo that a shift to a 10 ft general purpose might allow me to spread the weight of the chipper on the bed better.
popped into my local trailer place today - who was a ifor Williams dealer
Β
they are about to change brands to a competitor - but cant tell me who yet...
Β
Β
There is a lot to be said for some wiggle room. I've found on some plant trailers you just haven't got the room to achieve good weight distribution.
Β
Something like an lm125 with ramps could work. If it's behind a 4x4 the 1.75m width is a bonus as it's the same or smaller than the vehicle. Comparitevly cheap as well.
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
