Has anyone changed the bearings in a ribbed jockey wheel to something more substantial? Obviously they are not designed to lift a loaded trailer off of a towing vehicle but sometimes needs must!
I'm assuming I'm not the only person to have come across this problem?
I replaced the crappy plastic thrust bearing in my Ifor Williams jockey wheel to a steel one. I sourced the bearing from my local bearing supplier. I had to elongate the hole that the roll pin went through with a round chainsaw file as the new bearing was thicker than the original.
Hope this helps. On another note. Some unpleasant characters stole the trailer last Feb. It was a 14ft trip axle S/No. 446 006 I fitted additional rear side marker lights which if removed would expose drilled holes. If anyone comes across the trailer I would dearly like it back and would happily offer a reward.
Sent from my iPhone using Tapatalk
The tri axle trailer was a model LM146.
The commonly seen trailer with removable sides and ramps that slide underneath
Can you remember what the sizes were?
I took the jockey wheel (in bits) to my local bearing supplier, Hayley Group, they are really helpful and measured it up. Sorry I don't have a record of the exact bearing. But I would recommend making the effort to put the steel bearing in, pack it with lots of grease and forget it. ATB
