  • Replies 82
Hi SLACK Any chance to see the new light bar on the front be nice to see in action thanks John
Lights on the mighty Nuffield, ha ha good joke :lol:
The lights are on the Zetor, if i remember i will take a couple of pictures for you on Friday.
Hi SLACK NO JOKE ME how is that gard I sold you doing thanks John
Hi mate yes it was old major good old thing we had 250kgs weight frame on front help keep the front all you need to do is make sure the winch butt plate is well into the ground before pulling and do not pull out of line thanks Jo
n
Sounds ideal John. Did you make up the frame yourself? Any pics?
Beep beep, make way for the mighty Nuffield, with a Fransgard twin 3.5 winch.
Lush it is.
Sorry i don't have a close up, but there are a few of my videos with it working.
Hi Slack Ma Girdle. That looks like a beauty! Nice wide footprint and beefy rear tyres... bet you get some good traction with that set up?
Do you find that the 3.5 tonne winch is powerful enough for what you do? Be interested to see the videos you mention.. where can I find them?
Cheers. Rob
n
Cheers. Rob
Hi ROB AS you look at main side rails on the sides were engines bolted in come out from the front with weights 450)600mm on front I've some nice 56lbs weights here I used thanks Jon
Absolutely not for assisted directional felling; too slow.
Hi TimberCutterDartmoor. What would be your winch recommendation for said tractor, for assisted directional felling? (tonnage etc).
Cheers. Rob
Have you not shifted those weights yet Jon ?
Hi SLACK I've 7)8 56lbs weights you after them then they're good for key in the front of the tractor going to push you know tractor as a cheap £10 each cheap as chips thanks John
