I have an old Maktec one I brought about 10 years ago for £20. It has done loads of heavy sanding on Alaskan cut boards with a heavy grit , shaping of woodcarvings , cutting and grinding of metal and refuses to die ! I would buy another, in comparison I brought another make and it lasted half a day before the bearings gave up.
Maktec is makita 👍🏼
  • Replies 21
I've been looking at Makita with paddle switch and have just found a Bosch with paddle switch. May get a lathe in time too. Thanks for advice.
Yes defo mate also a dremel wouldn't be a bad shout as you can do loads of stuff with one them. Relief carvings patterns, lettering, Engraving sanding. Tons of stuff to add unique touches to your bowls.
