[ATTACH]196329[/ATTACH]
[ATTACH]196330[/ATTACH],major gremlins with low preSsure fuel pump on my Iveco Daily , relay pointed out and fuse for anyone else with a Iveco..also for future reference the postive wire to pump can be located at the radiator (battery side ) where there are 3 junction boxes and the wire is light pink coded. 9156 .
Common problem with Iveco wiring very thin and open to the elements, spray has much lube on all junction boxes to keep corrosion out.
Low pressure pump £185 genuine Iveco , when these pumps start been faulty the injector light will come on and air bubbles can be seen on the red pipes by fuel filter .
Ultimately letting you down .
Ste
Edited by IVECOKID
  • 3 weeks later...
