Wot these ?
https://www.youtube.com/watch?v=1INfZGih4BM
Did Dif lock not use them for tying his billet bundles, and found that you could not get them tight enough to hold the bundle securely
thats them i have been using pallet tying stuff but it seems pretty wasteful i was thinking of a more reusable solution but if you can't get them tight enough maybe not as good as i thought
If you get away from pallet strapping that uses crimps and use Cordstrap, you get the option to re-tension when the billets shrink or if the timber shifts.
https://www.cordstrap.com/en/Products/Strapping/Composite-Strapping-and-Buckles/
The system isn't cheap to start with to get set up(£300 ish) but you won't look back.
thats what i am using but i have been making the mistake off cutting it
Leave an 8 inch tail minimum.... Ignore putting the strap into the cutter when you're tensioning :001_cool:
You can get reasonably tight without the tensioner, which is the expensive bit. I get loads of the buckles from our fencing deliveries.
