I'm getting a bit fed up of stuffing all our spare gear etc into the cab on my newish transit so to stop it getting to bad i thought i'd buy a tool box that fits under the tipper.
So i'm just wondering if anyone knows the best place to buy one from? I'm in Basingstoke if that's any help!
I've seen a few of the plastic ones which look quite good are there any other types you can buy?
thanks in advance, James.
Go to Boulder tippers in Tadley they will build you some I am sure.
Thanks for the reply, i might go and get a quote from them. I thought there would have been a "off the shelf item" you could buy though? I've seen a couple of transits around with them on and they look pretty standard.
We use these poly ones James. Euro Plastic - Truck Tool Boxes & Storage - Truck Boxes & Grit Bins
Dont under estimate the weight that can end up in them , they need a couple of sturdy lumps of angle to bolt too. You also need big washers with a drop of silicone under them to hold them on and stop the water getting in.
Bob
