You need to check the oiler hole is free in the bar, make sure the oiling channel in the bar mount is free of chip.
If using fuel in the oil tank has no effect then the oil pump will need to be removed and the oil pump blasted through with WD40 and the oiler holes made sure they are clear and also make sure the oiler pickup is clear.
This should do it unless the pump or oiler drive is worn/damaged!
