Difference, that I noted, between "standard" hedge cutting flails with swinging flails, is this head was the same as a forestry mulcher (and I was wrong speaking of "flailing" in my OP)
in that the tungsten carbide tips are rigidly mounted to the central shaft.
And unless I misunderstood rotate in the opposite direction, thereby vastly reducing the amount flung debris.
Mine is set up counter rotating, and it is not an issue, I fit a chain curtain to the front for public work, but the majority of my work is private,
And 200 feet is no problem for throwing missiles....😝
  • Replies 20
