the throttle butterfly is leaking air as it is so worn. i think the hole in the ally that the throttle butterfly goes through is worn as symptons went away when grease was applied.
can i fix that?
can i fix that?
If a squirt of WD40 to the sides of the carb changes the idle speed then it is new carb time, not much you can do to rectify that. I have had to do a 039 and 038 with exactly this fault.
thanks spud, i'll give it one last check before i order something
