You'd only really need the student one i think. Pop into a Deere dealership and ask to have a look at one if they have them. That would take it down to about $50 a book which is about £32.
Ag engineering books may also be worth a look as they will cover compression ignition, hydraulics and electronics.
As for a good collection of tools to start doing machine repairs.
Spanners 6-32mm and you really want two of each but at least 2 of 13 15 17 19 22 24 27.
Sockets
good 1/4 drive kit
good 1/2 drive set
If your doing big stuff like tractors then a 3/4 set it worth having too.
Torque wrench - chipper bolts & wheel nuts
Hex & Torxs bits on 1/2 drive
24" scaffold pole
Ball pein hammer
Lump hammer
Assorted screw drivers from little one to big ones.
Pry bar
Chisels & punches
Pliers - needle and regular nose and side cutters
Circlip pliers -need 3 types
Mole grips - good set in two sizes
Adjustable spanners - good quality 10"
Multi meter - good one
good LED work light
10 Tonne bearing puller set
Axle stands x2
Bottle jacks
Filter wrench
Bleed kit
Trailer plug tester ( Worth every penny)
I think that is most of the stuff in my tool box. Obviously the deeper you get into it the more you get. I think that would cover most chipper/mower stuff though.
I've taught myself a lot through breaking things and putting them right. The more you know about how each bit works the easier it is to fault find whats wrong.
Complete tosh
All you need is some cable ties and a roll of gaffer tape:laugh1:
Complete tosh
Oh i forgot those things that's how you label all the bits you disconnect at either end. Oh and a camera phone to take pictures of it before you take it to bits.....
