Lawnflyte LS65P splitter help
Magic rat
Morning folks, need some advice on the above splitter.
Got a problem splitting this morning, return action got slower for a couple of returns then stopped in the down position and won't return.
Engine running fine, hydraulic oil level good.
No leaks or pipes loose.
Any suggestions, before I have to return it, which is a faff to drag it on wet ground to where I can get a trailer to.
Had a similar problem, I'd buggered the rod somehow, the ram stroke got painfully slow, then it wouldn't move down if it encountered any resistance at all.
Sent it back to be fixed, which it was, and they're trying to sting me for £80, which I don't feel like paying as it's less than a year old and I think it should be a warranty issue.
I haven't abused it, but it's a bloody sod to move around on those crappy little wheels, so does get shaken a bit.
Good luck with it.
