It's in the picture on the 1st post.
You're most likely to find the plastic has warped, the only fix for it is replacement of the plastic casing. I've had saws like this, only homeowner grade, as they are usually the ones with plastic side casings. You're best off contacting the dealer you purchased the saw from
Well spotted - it looks like it may be a bit flat on one side but it could be the flash, also worth checking the receving hole is clear of crap otherwise it will distort the cover.
Warped covers can be straightened a bit with a heatgun and brute force:thumbup:
  • Replies 20
