Hi all just a quick question,
Awkward job coming up and i'm wondering if I would be able to negative rig timber down using a very basic setup, ie. Endless sling , swing cheek pulley and rope and if yes how much regarding size would be acceptable on the system, no base friction device though.
Thanks
Edited by karl1991
  • Replies 41
2t rating as anchor for pulley with steel krab.
Just awkward, will be able to chuck so much but there is a green house and shed in front of the tree situated at bottom of garden and only a 2/3 ft crazy paving path.
The branches are no problem I'll rig them down, I'm on about the stem, I have a greenhouse and shed under the tree and a small path between the two roughly 2 or 3 ft wide, as a landing point, but i don't want it obliterated by dropping everything in one area then there's the risk of bounce or roll into the greenhouse, I won't be able to chuck the timber over the top of the greenhouse as there is a small veg patch next to the greenhouse, im hoping to chog the timber down on itself. Thanks
