Would this hydraulic saw manage on a large processor?
Chipy
well power is pressure x flow rate for hydraulics so from the mid point of it's spec you'd have 30x150 /600 = 7.5 KW - compare that with a petrol saw - for example a Stihl MS880 is 6.2 KW - does that help?
(Assuming I've not screwed up on the calculations!)
You just cant compare the systems like that. Hydraulic systems work at much lower speeds but have much more torque. Completely different characteristics.
