aftermarket pot and piston for stihl 064
justin131
Some 54mm P&C's will fit without a problem, others won't. Depending on how old the case is you'll need to adapt the holes in the cylinder base to fit and it's best to change the bolts from M5 (064) to M6 (066). When these changes are needed, you'll probably also need to grind a little bit on the cases to clear the piston.
I've got a old 064 here with a 066 P&C on it and that fits without adapting anything, just replaced the crank, case and piston (new Meteor) and that happened to fit also. The original case had 1.1 stamped on it, the new one is stamped with 2.1. So hard to say when a 54mm will or will not fit without trying it out.
